Street Demon 625 Carb
Annapolis76EB
Annapolis, MD
Since I am really grateful for the information everyone provides on parts they have tried I wanted to pass on my thoughts on a new carb EB66to77 and I put on my 76 with a 5.0 roller motor, stock Mustang cam, and Performer 289 intake. The carb is the new Street Demon 625 and the version I bought (1900 model) can be had with a coupon code from Advance Auto for under $300. The carb has many similarities to the Carter/Edelbrock but is also very different in many areas. I wont go into tech details since I am sure the manufacturer can do that better than I. Even though the 1900 isn't supposed to be chrome or polished, it looks like polished aluminum and goes will with the other chrome and billet parts in my engine bay.
I did a lot of research before buying this carb and was worried it would be too big. I called Demon and they assured me this carb was designed to work with lower displacement small blocks as well as much bigger V8s. I couldnt find much info on theis carb on a SBF but I found reviews from Chevy guys that loved them on their 305s and 350s.
The carb fired up right away right out of the box and a turn or so on the idle screws had her purring. After doing a few test runs with it, it was actually running slightly lean. After a quick rod swap it now runs great. The most impressive part of the carb to me is the crisp throttle response. The slightest pressure on the pedal and the carb smoothly responds. Blows my Edelbrock 1406 away. I only have about 100 miles on the carb so far, but at this point, I personally rate it higher than the Edelbrock 1406 and Holley Truck Avenger 470 on the road (those are the only other carbs I have experience with). Sorry, but no experience off road yet. Hopefully this is helpful to others looking at this carb. Here is the link to the carb on Demon's site.
http://www.demoncarbs.com/1900.asp
broncnaz
Id say closely based on the carter/weber/edelbrock carb. With only minor differances. Id bet that jetting kits, floats and needle seats are edelbrock parts. Its probably that tripple booster setup which effectively reduces primary CFM flow that enhances low RPM throttle response.
Looking at it I dont think its going to be much better than a edelbrock offroad. But maybe you'll get lucky. Worse yet if you need to rejet or adjust the floats you have to remove the whole carb to take it apart.
C Saporito
Demon Carbs are great! I have a 750 CFM Speed Demon on my 408, ran good right out of the box. Adjusting is easy if needed.
El_Ducko
LA LA Land
Any word on the offroad performance?
Or find any grass berms to point the nose up and see if she idles happily along? I have been stuck trying to figure out a way to ditch my TA.
Annapolis76EB
Annapolis76EB
Annapolis, MD
Havent done any off road with it. It is really a street truck, and for that purpose, I freaking love this carb. Massive improvement over my Edelbrock. I love being able to adjust my secondary opening speed in literally 10 seconds. If I find somewhere to get her nose up I will give her a try.
