I have a couple of questions before I start the 95 5.0 swap.
Question #1. What is the best material for the distributor gear bronze, graphite, or stainless steel? I used a bronze gear the first time.
Question #2. What flexplate should I use, a 95 5.0 flexplate on a c4 or use my old c4 flexplate that I had rebalanced to the 95 flywheel weight? or simply what will work best?
Question #3. If I use my old 70's 302 Timing chain cover on the fresh 95 5.0 will everything from the late model 92 5.0 stuff bolt right up? I had to rig some hose parts to make the 5.0 waterpump match up to the radiator. I would like to use the old timming chain cover because of the mechanical fuel pump. I had a couple of the electric ones give out on me, thank goodness I had a spare to get me home.
any help on any one of my questions will be appreciated. Thanks
