la77
for the gear heads here is the situation. I have 4.10 gears d44 (lunchbox locker) and 9" (detroit) and 35" tires. buddy with jeep has a bronco d44 with same setup but 4.88 gears and same in rear with detroit. swapping to d60 front and rear. will let me swap whatever I want with his stuff before he get's rid of it and I want lower gears for 36 tsl sx tires in the near future. he doesn't have alot of miles on his setup. can I take the setup out of his d44 gears, carrier, shims and replace in my housing and the tolerances be the same? would just swap the whole shebang but he has leafs up front so he cut off the C's. I'm a cheap SOB and don't want to have to pay for another gear setup and don't have the tools or patients to do it myself except the way i described above ( take everything out and place in mine exactly like it came out of his , the shims and all) not sure if there is a big difference between axle housing one to another or if stock bronco d44 toerances are excatly the same or not. thanks guys. whish the front was as easy as the back.
