PTG in MN
Hi Guys,
I'm a new owner of a 68 half cab. The transmission is a 3 speed (shifting on the column).
I noticed the upper left side of the transmission housing has a crack on it that was patched with JB weld by the PO the patch is stating to peel off (as expected) It leaks out slow, but I want to make sure the transmission always has fluid till I get this fixed totally. Until I replace it some day.
Can anyone let me know where the filler hole is on the transmission? And also where is the fill line (if not the filler hole itself)
I'm ordering a shop manual so eventually I wont have to ask this stuff.
As for the crack in the housing what's the best patch material for now to use again? JB weld?
Any help would be appreciated. I'm plowing snow again tonight and want to make certain everything is lubed properly.
Thank you,
Thank you,
