T18 Trans tunnel
Pedestrian
Bronco Missionary
I am installing a T18 anybody got pictures of the trans tunnel and how much you needed to cut to fit? Or any dimensions for cuts to the trans tunnel?
68 Bronco, no body lift.
red hot71
kent wash.
I did this swap about 12 years ago with the t-18,and at the time jeffs had a floor panel he made and it work well on this swap. I measured mine and it starts about 1 1/2" in front of the stock t-case opening, the plate measures 10x10" with sides that taper to a point,the top of tunnel which is flat moves forward and then angles up into the firewall that is were its removed. Also you will find that there is a floor brace that will also needs to be cut and caped. From here you are are own as I made my adapter and made it shorter so as I didn't have to very my driveshaft lenths,but as for the shifter location the 435 & the t-18 those are the same from what I remender.
OX1
Pics...............
OX1
Ended up stealing part of the tunnel off a parts bronc I had to cover the 3 speed floor shift hole and the rear of the hole needed for T-18 install. Used the std 435/T-18 cover plate to go over top of shifter plate.
Pedestrian
Pedestrian
Bronco Missionary
Excellent pics OX. Curious if I could tilt the motor enough to avoid the length of hole needed to slide the tranny into the bellhousing.
Also how much body lift are you running?
Did you have to move the transfer case cross member? How much?
OX1
I jacked the front of the motor up and it wasn't even close to enough. That was the smallest hole I could get away with.
No body lift, which was what made it as much of a PIA as it was.
I egged out holes that mount crossmember to frame brackets about 3/4 inch.
I also swapped thicker for thinner TC tunnel mounts, allowing
TC and tunnel to sit a bit lower. This helped clear back of TC with other body
crossmembers that normally sit jsut rearward of the TC.
It did create a problem with one of the TC shift rods, which I had to grind out a bit on the top of the crossmember to get the shift rod all the way forward.
All works great and was worth it as I in no way wanted any body lift.
