Temperature gauge question
kaisermusic
Chehalis WA
Hey just got done installing a new radiator in my 67 and am now 80% sure my temp gauge is screwed up.
At idle temperature it shows 160 degrees. It should show 190 right? That's the thermostat temp I put in a month ago I think.
If it is my temp gauge, how do I go about testing it and fixing it? I do not want to add a aftermarket gauge. If anyone here rebuilds the gauge I would be interested in getting mine done.
Scott M
Baltimore
i'm sure somebody will chime in
on an easy way to actually read the temp at the engine and compare it to your gauge. but my first thought is just try a different sending unit. they are cheap. hell there mmay be a way to adjust the gauge somehow. maybe not (me thinking out loud, but somebody w/ more knowledge than i about gauges will know).
you did say it was a 190 t-stat right? and that you took it our for a run to let everything get good and hot.
SaddleUp
Vancouver, WA
You can either use a meat thermometer or you can buy thermometers for checking the coolant temp pretty cheap at the parts houses. As to adjusting it the stock guages are adjusted at the guage voltage regulator. If the temp is off then so are the other guages. (I.E. Oil Pressure)
K
kaisermusic
Chehalis WA
ok well its the only gauge that is off as far as I can tell. I have the cluster that just has light ups for OIL and ALT, and I know they don't light up at startup.
The sending unit is brand new, the thermostat is brand new, I can't think of anything else to replace?
If the temp of the coolant is on with the gauge at 160 deg. , why would it be running cold?
I never heard that if one gauge is wrong, they all would be wrong?
Most the broncos I see have a bad gas gauge and nothing else.....
sbingham2
Cedar Park, TX
I agree SaddleUp about checking the temp with a meat thermometer, it will help to narrow things down.
A couple of other things to think about, a bad ground cause cause the gauges to read off, the temp gauge can read up to 15 degrees off if there's a bad ground.
Also, make sure you have the correct sending unit, or that the new one works right. Toss in the old one and see what it reads, or use an ohm meter and a pot of boiling water to make sure the two are putting out the same ohms at the same temp.
You should also avoid using thread sealant on temp sending units. This is really important with EFI setups, the sealant/tape can cause false readings. Brass is soft enough to seal without any sort of tape.
SaddleUp
Vancouver, WA
If it is actually running cold then it is probably the thermostat opening at the wrong temp. (I've seen several new ones that did not open at the stated temp) As for the guages all being off they have an adjustable voltage regulator that stabilizes the guages. It is pretty common for the regulator to be out of adjustment which will throw the guages off slightly. Since you seem to have a problem believing what I say on this run a search for this problem here and you find that several others have had their guages be off because of the regulator being out of adjustment.
K
kaisermusic
Chehalis WA
I don't have a problem believing what you said, I just have been told otherwise by other people on this board. This isn't the first time I posted about this issue. I got so many different answers last time that I don't really know heads or tails at this point. Just eliminating as I go.
I didn't mean to sound rude by saying that I had heard differently from others, just stating the facts. Please don't take it the wrong way.
74bronc
i will vouch for saddleup here seeing as I have adjusted that little bugger a dozen times on different broncos. it most definitely adjusts the guages, everything except the ammeter because that is hardwired into the charging system and isn't a part of the oil press, engine temp and fuel guage circuit. look it up on a wiring diagram. i would temporarily install an aftermarket gauge to verify your running temp and then adjust the little screw on the back of the cluster voltage regulator until they match up.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
If the fuel gauge is accurate, then the Instrument Voltage Regulator is most likely accurate too. Oil pressure warning lights are usually calibrated to come on only when pressure is VERY low, so a slightly off IVR wouldn't cause a noticable problem with it.
Another thing to check is resistance in the wire between the temp gauge and the sending unit. There shouldn't be any resistance if the wire's still good, but it's 40 y.o. Who knows what the strands look like inside the insulation? & if it's hangin' too close to the exhaust the heat could cause excess Ohms & a low gauge reading.
But like the others have said, using a thermometer to check the actual temp is how you tell if it's accurate or not.
K
kaisermusic
Chehalis WA
I figured the easiest way to test it is the aftermarket gauge. I think I will try that next. Does anyone have a pic or diagram of where to adjust the temp gauge if it is off? I have the original Ford shop manual and maintenance and luberication manual, but I can seem to find this info.
Thanks to all for your help!
