I crawl under the EB to top off my transfer case before a big event coming up in my area (I had noticed a few regular drips). I go to top it off and find it takes over a quart! As soon as I fill it, it's starts leaking out the front output yoke seal. I pull off the driveshaft and literally it's just pouring out around the yoke.
While I was under there, I noticed one of the 2 shift rods for my 3-sp column is entirely disconnected with the pin missing!! WTF how did that happen and still be drivable.
While inspecting that, I found my ebrake return spring lodged between the frame and my exhaust. Obviously it decided to pop off....
So now I'm scrambling trying to get fixed for an event 2 days away. I call my local ford stealership for the TC seal and the parts counter can't even look up parts earlier than 1980!? called the local pepboys/autozone, all special order... I'm hurtin...
