Normally, the oil pump drive shaft goes in during assembly. It is suppose to be held in place by a ring that is forced over the the drive shaft and will prevent it from coming out if the and when the distributor is pulled out. If, you didn't do that and don't want to pull the oil pan back off, remove the oil pump to correctly install the drive shaft you "can" put it in from the top, but there'll be nothing to stop it from coming out with the distributor and most likely falling into the oil pan the first time you pull the distributor out. If you elect to put it in afterwards epoxy it into the end of the distributor to prevent the "in the oil pan" trick. If you epoxy it into the end of the shaft you'll have to align both the cam gear and the oil pump hex drive to get everything together. You can do this by getting the cam gear partly ingauged and then while "gently" holding down on the distributor bump the engine starter. The cam gear will turn the distributor drive and the oil pump shaft into alignment and it'll drop in.
Another question is "Did you prime the oil pump??????" You should do this before installing the distributor. You can use a reversible 1.2" drill motor, two 1/4" drive extensions and a 5/16" socket. Electrical tape these three tools together (to keep them from falling into the oil pan). Chuck it into the 1/2" drill IN REVERSE and run it untill you feel resistance (the drill motor will slow down). You'll also see the oil up in the valve train. If you don't do this it'll be 30 seconds or so (if you're lucky) before you get oil pressure and you may ruin bearings.
Good Luck
