Thinking about installing 700R4
BlackHorse
Thinking about installing the 700R4 any links, tips, sugestions for shifters etc. Thanks!
Desert Thrasher
Why not just go with an AOD? All the adapters are available to attatch it to the D20 Tcase.
B
BlackHorse
I was told the 700 has a lower first gear 3.06:1. I think the AOD is 2.40:1 The low first is the main reson I'm looking at the 700. The adapters are avalible from Advanced.
cobranco
Zeeland,MI
If my C4 goes splat this summer (for the 4th time in two years) I'm switching to the 700R4. From what I've read its the berries, and the cost is about the same as an AOD.
bpassmore
Houston, TX
the 700r4 and its sister the 4L80e are both stout transmissions if built right. If i was going automatic this is what i'd do. I know Tonto wants this as well (at least thats what I remember)<br><br>These things can be made to be bulletproof.
tonto
It’s been a while since I read the info on Kincade B. web page so I’m not sure if he covers the header issues, but I think if your running a 5.0/302 there are clearance issues with the bell housing that may not be an issue with the 5.8/351, but there not anything that should keep you from deciding to run the 700r, as long as you not afraid to cut and re-weld the passenger side header.<br>Guys I know running the 700r have had manual valve body’s built for them to give the ability to take off in 2nd and hold it for use primarily when in low range. <br>Here's the link for Kincade’s webpage on the 700r for those just tuning in. Take Care, Francois.<br>
6677ebman
Any of you guys need a 700R4, let me know, I'm friends with a retired fellow who built transmissions for GM (Detroit) for 40+ yrs, he retired back to AL, and picks 'em up & builds them in his spare time, has piles of them, built & ready to go!
BroncoKidd
Gainesville, FL
Go buy Feb '03 Peterson's 4x4. They did a NICE build of a 700R4 with the full reverse manual valve body. This thing was awesome! They wired in a switch to control lock-up in first gear, to act as a compression brake. And with the reverse valve body it shifts P R N 1 2 3 D instead of P R N D 3 2 1, that way first and reverse are next to each other. There were a bunch of other tricks they did to it, they even found a way to push start the motor with the auto. Check it out, lots of info!<br><br>-Dustin
RobsBronc
sandy, ut
my buddy did exacly what the 4x4 mag did about 2 years ago with his. its lasted pretty good with the 450+ hp 383 and a 4.11 10 bolt. but once he put 4.56s in a 14 bolt he blew up just about everything that could blow up. i think as long as its a mild motor you shold be fine with a stock 700r4. i would recommend finding one of the newer ones with 30 splines for a little more strength. if you live near utah im sure we could build you a serious r4 for ya.
BwoncoHowie
C-4 Wizard
[quote author=cobranco link=board=5;threadid=13283;start=0#99786 date=1042565260]<br>If my C4 goes splat this summer (for the 4th time in two years) I'm switching to the 700R4. From what I've read its the berries, and the cost is about the same as an AOD. <br>[/quote]<br><br>If you are going through C-4's this often, It sounds like you got the wrong person working on it...<br><br>BH
