third member swap questions
snick
Searched but didn't find the answer.
1. What ford model and year truck 3rd members will directly fit into my '76 9" HD rear if I buy larger 31 spline EB axle shafts form one of the vendors? 78/79big broncos? 76-79 F150s?
2. Did any of the trucks whose third members will fit come with 4.11 gears?
I'm trying to upgrade to 31 spline axles on a buget and switch to 4.11 gears on a budget. Later on I plan on upgrading to a detroit locker in the rear but don't have the money to now. I already have a disc D44 with 4.11 gears but can't install it until I switch out my rear to 4.11 gears.
Apogee
Tangent, OR
All of the Ford 9" third members are interchangeable, so it's just a matter of finding one with the spline count and gears you want. That said, the spline count shouldn't be too hard considering most if not all of the F150 and E150 applications with 9" rear ends came with 31-spline axles. There were a few cars as well, but those will be like finding hen's teeth compared to the F/E-150 dropouts used from the mid-70's up through '86 on the E-150 vans. The most common gear ratio will be 3.50, some will be open and others with have the Trac-Loc limited slip. Either way, you're probably better off finding the chunk first, then tracking down gears if necessary...used 4.11's are not that hard to come by.
FWIW, most of the factory 4.11 ratios will be found in the trucks/vans equipped with the 3.9L or 4.9L I6 engines.
