Thompson power steering pump serpentine pulley?
harleyabarton
Jupiter
alright I've got a 66 U14 that i'm putting power steering in I've installed the steering gear box and steering shaft (swapped it from my 75 which i did a FULL restoration on) basically I've got a 302 or 289 under the hood but when i bought it it came with a serpentine pulley set up. id like to use the original Thompson pump from my 75 to power my 66's power steering gear box. my issue is finding a serpentine pulley for my pump. does anyone know a vendor that sells serpentine pulley for this pump or at least no the pulley shaft size of this pump so i can find or fabricate my own??
also if anyone has or needs advise for fitting the steering shaft in a early 65 (66) let me know Ive already down it ahahha.
jrwyant
I don’t recall now which junkyard vehicle mine came out of, but the “5.0 serpentine” pulley on my Thompson pump has the raised-print marking “E57C-BA” on it. It fit the Thompson shaft perfectly.
I’m not answering either of your questions though. I should write what vehicle I removed the part from, on the actual part, for better record keeping.
H
harleyabarton
Jupiter
Thanks so much i found that exact part number on ebay so im going to try that out! i really appreciate the help!!
