that sounds sweet especially the no chigger part. I just did an inspection on a hanger today for hobby lobby exsA lot has happened since I went house shopping. Greeley was my first plan, but we found a house with a 46'x46' hanger, an additional heated single bay on one side of the hanger with roll up door, & a 2 car garage on the house. It's 3 miles east of Brighton in an established air park community. Dave will know it, its about 10 miles due north of DIA. So I'll have a home for the Maule plus some Bronco shop space. The house is solid but would benefit from some interior updates and landscaping.
I haven't got a chigger bite in 3 weeks!
Love the gable ridge detail ... going to copy that in the next !
Its also in Washington state franko. Different building codes.
cool ...
my I see the signed and sealed truss engineering ?
they are 3-Ply / 96" O.C. ? 6/12 pitch ?
any and all gable end trusses should be always 24" O.C. studded / have a 2x4 vertical at max 24" O.C. for plywood sheeting ( see pic ) ! if you have plywood joints w.out truss member backing you must install 2x4 cats / blocking . ..sorry dont see that w. yours !
I had a custome 40x60 Pole Barn built. 14ft side walls, OSB sheathing on the roof and walls. Insulated it, and put up OSB walls on the inside. All that's left is a self-contained heat/AC unit on a slab behind the building, ductwork in the rafters, and then a ceiling.
I literally provided my builder this drawing I made of what I wanted... and he built it.
I did 14 ft sidewalls, to accommodate a hoist. I also gave a garage door designated to it.
Epoxy floors are a must. Do them before you put anything in it. You can do it yourself. Bought the kits are Lowes, did it on my own. It's all in the prep work. Do it before you get greases and grime on the floor.
You can NEVER have too many outlets. I also went with LED lighting all the way around. From the lights under the widows peaks, to the goosenecks on the outside, to the 4 tubes inside. All LED.
