Wild horse 75
While distance is important that can be overcome by height in relation to fuel level. If you can mount the pump below the fuel height the pump won’t have to work as hard sucking fuel as there will be a siphon effect going on. That’s why they say within 18” cause it can draw fairly well even uphill that close. One other thing no one has mentioned is life span. The cooler a pump can remain the longer it will live. So the less it has to work the better. In tank mounting has the added benefit of fuel to keep it cool. You may want to look at retrofitting an in tank setup into your tank. There are several options out there. You will need to have a regulator and return line as they create too much pressure for a carb but you get the benefit of cooler fuel at the engine when fuel isn’t sitting deadheaded in the line under the hood. All things to think about.
