tig welders
badbronco
south carolina...
I am currently looking at buying a tig machine.220 volt probably a Lincoln. I can mig weld good but i have never tried a tig. I was wondering who here has one and how much harder is it then welding 18 gauge sheetmetal with a mig VS a tig machine? This is just a comparison because i feel its kinda tough to weld thin metal without warping it. Can a tig weld thin metals? How exspensive are consumables? Do you have to switch rods for different heat settings? I have not a clue about these machines...please help. I do know that they make beautiful, very strong welds. I really want this so i can weld aluminum also.
Madgyver
Bronco Madman
Tig machines are awesome and also expensive!! With the high frequency stuff you could weld aluminum soda cans together! Might be to expensive for a home mechanic to have but it would be nice to have it. If you can do Oxy/Acetylene brazing, With a little practice with the controls (foot pedal) and settings you could learn.
It's intimidating at first but if you brazed before it should be easy to pick up. I suggest you go to a welding supply store for a demo and trial, Most place let you try it out first. A tig welder creates no flying sparks and if your good ehough you have total control of the bead, just don't sneeze while you're welding. One hand controls the arc with a tungsten tip and the other hand hold the filler rod. Be aware of the DC tigs only. They will only tig weld mild-stainless steel. You'll need an AC/DC tig to do aluminum.
You could weld aluminum with a correct mig welder also. You just need the proper attachments and a spool gun.
This is what I played with. I did some awesome weld beads on 1/8" aluminum stock with this, I change the settings and filler rods and did the same to the 1/16" stainless steel.
This is what I have.
This is what I need for it to mig weld aluminum
T
teknalee
Guest
ohhhh more info we're buying a tig welder very soon ;D
mad that one on top is one of the welders we're looking at buying.. any other suggestions?
T
teknalee
Guest
heh, that's exactly what else we're looking at. will that weld a 1/4 inch of aluminum?
mxpaz
KC
Hmmm, IMO I wouldnt get a TIG. If you need to weld aluminum, set a mig unit up to weld aluminum. Tig welding is very slow and the metal has to be very very clean to get a good strong weld. You can warp metal with TIG also. It is a more controled heat so its easier for a good Tig weldor to not warp the metal as bad. O and you have to set your machine up differently for steel and alum. If your getting it cause you want a new toy to play with then thats would be cool but if your getting it to try and be your main garage welder I think its not the best idea. As far as buetiful welds go they are from someone whos done it a lot, its way way harder than mig welding. There are lots of tricks you need to know to tig weld. Hell the way you sharpen your tungsten is dif on what kind of metal your welding. If you know someone who can show you it wont be to bad but it will take you a long time to figure it out on your own, but good luck either way. one other thing, get a job as a weldor and learn how to tig while your getting paid.
T
teknalee
Guest
we already have an awesome mig machine with a spool gun. we're making tree stands, these racks for coolers and gear that go into hitch recievers etc. and doing some welding on our aluminum center console boat that we want to look nice. thanks for the advice mxpaz !
