RadioFlyer
- Dec 17, 2007
- 114
I have heard that these are compatible with EB's... Is this true? Any conversion tips?
Mine will tilt down between my knees but only has one click above where I use it whick is almost straight ....So check this before you weld the bracket back on ...Welding the bracket on you can adjust how far away from your belly the wheel is ...
Yes I liked mine after it was finished .......You'll need one or 2 U-joints 69.00 each ...I used one one the gear box don't remember up top ...Mine will tilt down between my knees but only has one click above where I use it whick is almost straight ....So check this before you weld the bracket back on ...Welding the bracket on you can adjust how far away from your belly the wheel is ...
I did mine with a manual tilting column. Used the wiring diagram on BC's site and moved the flasher switch to the column. works well and looks great with my Grant wheel. get the wiring diagrams though yours may differ a little.
TOFIC
