Tire width/wheel width
G
Guest
Guest
I just got a 73, and it has 33x12.5x15's on 15x12 wheels. The problem - the tire tread sticks out beyond my fender flare. This is a no-no here in Vermont, and my rig won't pass inspection. (I also would prefer something a little narrower anyway).
My question - I see lots of Broncos that have tires this same size, but it doesn't look like they stick out so far. Is my problem actually the size of my wheels? If I had narrower wheels would it actually bring my tires a little closer to the center of the vehicle?
On a related note, will my Bronco look too far off of the wheels if I put on some shorter tires (like some 31x10.5x15's). I have a 3.5" suspension lift.
jeev
VEGAS BABY!!!!
It is a combo of the wheel width and the back spacing of the wheel. A 12in wheel is wide but I think it looks great on EB's 8). You have a couple of options - Get wheels that or 10in or less or buy some bigger fenders. I say get the fenders it will probably be less expensive and it will look a whole lot better (James Duff has some pretty wide ones). As far as putting a smaller tire on there..... I wouldn't put less than an 11.5 on a 12in wheel and you wont see to much of a difference in one inch plus I dont think it would look right :-.
G
Guest
Guest
i run the same size tire on a 15x10 and no problem.
you can run them on a 15x8 also. duff makes a wider
flare also.find a freind with diff. wheels and put one on.
if you are having fun you are still going yo get mud
on the body.i think smaller wheels is the deal.hope this helps? party on in the dirt and rocks.
lj
ASE-73
Seattle, WA
12.5" Tire on a 12" wheel does not leave much sidewall flexibility ... and puts the tire 2" further outboard, assuming you are at maximum backspace (as much rim set inboard without interference). Better to go with 10" wheels (maximum) with these tires ... or even 8" based on your intended use.
jeev
VEGAS BABY!!!!
[quote author=tpc link=board=5;threadid=15688;start=0#msg118713 date=1048715473]
[/quote]
I have 4 15X8in black replica rockcrawlers that are in great condition and I just took off my 66 that I would be willing to get rid of for $50 + shipping (there just taking up room in my garage). Let me know if you are interested - I have picts.
snj.prs@verizon.net
