Well the latest project is in the books. After much research here on the forums, and long deliberation, I decided on the TBP kit. I read a lot about other kits having issues being full width at the kick panels, etc. Regardless of other kits' quality, which I can not speak to first hand, I went with Toms and couldn't be happier. The fit is second to none. No kick panel issues, It's dead on. The tunnel, floor pan drop-off, and rear inner fender seams are all spot on. Here are a few pictures of the install. I opted to buy the insulation locally. Anyone in the Oklahoma City area needing anything, Gibson Trim Supply has everything you could ever need, be it carpet, vinyl, insulation, etc. I paid $10 a sq yard for the nice heat shield aluminum backed insulation. 4 yds was exactly what was needed. Without further rambling.... The pictures.
The floor pan I found when I ripped out the old carpet. Not bad, other than the 15 extra holes the PO put in the floor for a half-ass seat install.
The Insulation being jigsaw puzzled in. I seamed everything with aluminum tape.
Finally, the carpet. Still a few wrinkles here and there that I'm waiting to see if they will take care of themselves. I taped down the insulation and then glued the carpet in with heavy upholstery shop spray adhesive.
And..... Done
Installed A set of Corbeau seats from CCOR the next day. Pictures to follow.
And..... Done
