Toms power brake booster kit
TheLimeRanger
Doing the power brake booster install on my bronco tonight. I already have disc up front. Opted for the stainless steel hard line from the master but I’m going to use the H block for the time being and we’ll see how it goes. Toms’ lines don’t thread into the H block and they don’t seem to be bent the right way. They are bent as if the master cylinder fittings are on the drivers side of the master however the fittings are on the passenger side of the master. So what am I missing here ?
NashBronco
Flowood, MS
Watching this. I ordered the kit as well but have not installed yet. I did get the prop valve but that should not make a difference with the issue you have.
Bronco-Brian
Lake Oswego, OR
I think you are best to call Tom's and ask. They have lots of different master cylinders depending on drum/drum, drum/disc, non power disc, and 4 wheel disc. They will surely know what you have or need. Good luck
TheLimeRanger
TheLimeRanger
I was missing something, the correct lines lol. New set coming my way. Toms comes through yet again !
