Tom's Steering Wheel Install
JohnJohn
Richmond
I installed Toms bronco parts custom steering wheel a couple years ago and the black metal collar that comes with the kit is making contact with my column. It is only barely contacting it so I let it go but it is bothering me now because it has started to squeak.
Is there any adjustment in the steering shaft vs. column? I thought I read a post where you can loosen the column bolts and push it in our out separate from the shaft?
Or should I just grind down the black metal collar that came with the kit to make it clear the column?
I would have to take about 1/8" off for it to fit as it sits now.
Thanks,
John
phred
Earth
John mine did the same thing. I just filed the collar down some and that cured the problem.
tasker
all knowing of nothing
NH
must of happend while doing the RTI ramp.....all this from a trophy winner too!
JohnJohn
JohnJohn
Richmond
LOL...
It is a small thing that I decided to fix this week after the wife drove it to The Cove and back and complained about it.
I called Tom's and they also said to grind it down.
I am still smiling from ear to ear from last weekend. Man you all are great people!
My wife told me I better stop walking around the house with the plaque. I dont mind it under my pillow at night but she is complaining. :) :)
tasker
NH
will make a really cool belt buckle!
MooseyFate
Colo Spgs, CO
John, there is an adjustment that worked for me. The collar that holds the bearings in at the end of the steering tube. I spaced the collar away using two putty knives then tightened the collar up. I can take a pic later if Im not explaining myself very well.
