towing with dolly
broncobusted
Hello all in bronco land. I was wondering if anyone has towed their bronco with a car dolly and had any problems. I was planning on towing mine approx 500 miles, and was told by local rental that they wouldn't rent a dolly for a four wheel drive. This didn't make sense to me as the front wheels would be on the dolly anyway. Any input would be appreciated.
Thanks dave
okie4570
NW OK
Remove the rear drive shaft, as it's still turning the Dana 20. That may not be their reason for not renting it, but that's the reason you shouldn't :) There are several threads about this and flat towing.
Joe473
Picked mine up and drove 350 miles on a tow dolly with a 4.6 f150. If i did it again I would use an F250.
Reserve online and put in both vehicles and the reservation will go through. For short trips put tcase in neutral. Long trips remove driveshaft.
Take your time on accel and dcel and watch out for any dips in the road. Large Dips or expansion joints can shift tongue weight quickly or create suspension oscillation on the dolly.
Trailer is always better if you can.
sprdv1
REBEL
It's doable man, just consider the benefits of using a trailer if possible.
If that's the way you want to go though, go for it
ncsubronc
I towed my Bronco about the same distance on a dolly as well. We were moving everything we had so I was pulling with a 20' Penske truck and never even knew it was behind me. I had a caravan of family following me and noone ever mentioned anything happening so I'm guess it never got too crazy on me. ?:?
rastiss
Wichita falls, Texas
Uhaul auto transport is only $10 more any time I've checked and they are awesome. When I tried to rent a dolly to drag our EB home when we bought it, they were out of dollies and gave me a trailer for the same price. Having used both, the trailer is THE option I go for....
Techstudent
Missoula
+1 regarding the post by rastiss. I know U-Haul won't rent the tow-dolly to you if what you are hauling is heavier than what you are hauling with (which is logical) so you need to check the GVW of the vehicle you are using and make certain the hitch is rated for the proper weight. If there is a U-Haul facility in your area, you can probably get around it by reserving the tow-dolly yourself (going online and using their web page) and "lying" about the GVW, etc. I don't think I would do that though unless you are in a remote location and limited for options.
I rented a "car-tansport" for the same price as a tow-dolly and it was beautiful. No drive-shaft removal and it fit perfectly. Hauled it with a regular cab f-150 with straight six and no troubles for 200 miles. I highly recommend this avenue.
broncobusted
broncobusted
Thanks for all the input it sounds like the transport is the way to go. Thanks all.
Dave
garberz
Bronco Influencer
Conejo Valley, Ca.
Just a note on the U-haul car trailers, they work fine for transporting a Bronco, but the straps that secure the front tires are too small for most larger tires. Any tire larger than 30" I'd say, you'll need additional ratchet straps to secure it. Front and rear.
Mark
lowbush
Summerland Key, FL
You can also tow it backwards, with the front shaft in neutral it will not spin the T-case and therefore will not turn the transmission. Thats the issue, the transmission turning without the pump pumping will cause it to burn up. When the hubs are not engaged on the front axle it does not spin the driveline.
sdugs
Jax, FL
Flat towing is much easier. Just remove the driveshaft. I boiught a towbar at pep boys. used some 1/4" angle that i bolted throught the bottom holes in the frame under the bumper for a mounting bracket. Pulled it for thousands of miles behind the motorhome. Used a tow dolly for cars but flat towing is much easier and quicker to set up.
SEan
Jax Fl
68 and 77 EB
Teal68
Inlet Beach
Used a tow dolly many times with no problems. Twice to haul Broncos actually, but the last time was such a nightmare I sold the darn thing and will never use a tow dolly ever again! Period.
Rent the car hauler. It will work great, and is safest IMO.
R.P. Coltrane
Iowa, the flat part
NOOOOO!
Wrong weight distribution, that's a good way to find yourself upside down in the ditch. Even with a dolly the heavier part of the load goes to the front.
bax
Old Member
Towing with Dolly is OK but I have to tell ya. It gets old. First off the noise is constant. And then you find you cant get it out of your head You keep humming it over and over again. Working nine to five no way to make a living. And she dont shut up! Yeah I know giant tits but when she sits down their at her waist. I really would not tow with dolly any more than needed.
ILikeBond
<guffaw>
lowbush
Summerland Key, FL
Wouldn't the front wheels also be really squirrelly with reverse caster?
Not if you have enough truck to tow it. As was said you lock the steering wheel and you don't tow it fast. I tow in reverse around town quite a bit. It's no different than the scoop up trucks like the repo guys use. It's perfectly safe if you use a truck meant for towing like a 1 ton diesel which is what I use.
