I have a Nissan box. Look for an Xterra or 4WD frame Frontier (2WD desert runner OK) mid 2001 to 2004 for the best box.
Sector shaft is larger on the 4WD models. Some trucks were sold as 2WD but on a 4WD frame and these are good as well.
The mid 2001 to 2004 steering box uses a very standard 3/8" inverted flare fitting, so high pressure power steering hoses are easy to come by.
Pitman arm can be reamed out the correct direction and taper or drilled for heims (have have had both).
Use whatever power steering pump that you can find that will fit. Ford, Saginaw, whatever. I use a Sweet brand circle track pump for the past 5 years or so.
Earlier steering boxes back to '86½ will also work, just the pressure hose is a banjo fitting and is a little harder to work with.
Bottom 2 bolt holes line right up with a minor shave to enlage the mounting holes to ½". Upper 2 will need work as the don't align.
