According to different articles in different publications in different years, the EB's ran an ever changing track width, with some years being the same front and rear, while others were different.
Nowadays we can't use those old articles religiously, as the source of the info on some might have been from actual measurements, and others might just have used what the Ford PR department gave them to print. Either of which could have been in error, or even had a typo included to screw with things even more.
I say we should get together and measure the track on all of the different year models, both stock and with the two main disc conversions and put this to rest once and for all.
Be nice to have that little bit of extra info in our Bronco Database.
As far as being normal for Ford, I don't know that either, as Ford seemed to keep their track widths closer together than say, GM did on their '73 to '87/91 pickups. Those were visually obvious as well as well documented and consistent over the model years in that range.
Regarding your current experience bronco brock, you might want to measure each wheel in turn, to check not only backspacing but width. I've seen variations on both over the years. At least three people I know were sold two different width wheels, and in one case they were the same width but at least one had different backspacing.
Be worth a quick double check before spending on spacers.
