ntsqd
heratic car camper
Number 1 reason I will not be using the tranny cooler in my aluminum radiator, just don't want to take the chance.
There's no reason to fear the trans cooler in a quality radiator. Do need to be careful about installing whatever adapter fittings are required.I run a separate trans cooler because of the risk.
By not using the cooler in the radiator you give up the most effective cooler available (liquid to liquid is always more effective than liquid to air) and the ability to keep a trans warm when really cold. In the desert SW the latter may not be too terribly important, but in other parts of the Country it will be very important. The research that I've done over decades indicates that the trans needs to operate at 160°F at the minimum. This both reduces wear in the trans and will remove any condensation in the ATF.
