diestech74
My stock c4 in my 74 has started acting up if I put it in d it won't change gears I can manually shift from 1 to 2 but when I shift to d it won't pull is that a failure or a govner or something it's a vacuum Trans.if it is toast will any c4 work as in just replace the tail shaft out or is the 4x4 a different set up
