Trans/transfer case weight & advise needed
M
mtkawboy
Billings Mt
I looked at the Harbor Freight site yesterday and couldnt find the jack adaptor listed when I did a serach for it. They have a $48 trans jack that you run with a 1/2 inch socket, anyone tried one of them? Weighs 33 lbs, good for 400 libs capacity. Probably will cost more to ship then buy
DEANCURTIS17
Northern Virginia
I bought the 450lb tranny jack from Harbor Frieght for $50. Let me tell you, that was the best $50 I have ever spent on a tool. I took my 3spd and T Case out as one unit with a floor jack and a buddy. I had a friend help me get the unit on my new tranny jack and it went it perfectly! I couldn't believe it. You should get it, trust me.
shifter
Agua Dulce, CA
If you are talking about the scisser style jack from harbor freight I have one and it works great for the trans but for the transfer case something like broncobowsher rigged up is the way to go.
M
mtkawboy
Billings Mt
I think Ill buy the harbor freight one. It will cost me $40 to rent one twice anyway becasue Im putting the new trans on my old transfer case. Might as well own it for a little more. Im hoping with 2 guys, the trans jack & a floor jack I can get the thing in and out in one piece
jr
Mililani, Hawaii
I used tie downs (ratchet type) straps and slowly lowered trans & tc together. These can be found at walmart for $15.00. Wrap it around the bellhousing and the other on the output shaft. Wrap other end around frame then lower one side at a time. Use your floor jack and piece of wood to lift trans/tc then loosen tie downs and lower. I also used the same procedure to bolt it back in.
