Transfer case position in nv3550 swap
tampabronco
The transfer case was put back Close to the OE position after swapping my 76 to the nv3550. It hangs down into about the 7 o'clock position. The front drive shaft hits the cross member support and the yoke sits a few inches above the cross member support.
Should it have been moved up to the 8 o'clock position? I have read where some people have used the narrower cross member bracket from Tom's broncos and it fixed their problems. I don't wanna pull this thing again and start over. I've already ran my exhaust.
Any help is appreciated
Mitche11
I have the same problem. Wondering what you did to fix the clearance issues. Thank you Huge!
gregreed
My front drive shaft was close but worked.
tbratz
When I originally installed mine it cleared with no issues. I had to replace a throw out bearing and when I reinstalled the trans and TC it no longer cleared the cross member. I checked and the t-case was clocked in the same position, so I don't know what the deal was. I ended up grinding back about an inch of material from the cross member where the c/v joint was hitting so it cleared. That's what I did any way.
blubuckaroo
Grease Monkey
Ridgefield WA
I had no problems with my conversion, but I do remember the transfer case clocking options. I went with the stock position, but there were other options.
BRONCO26
SENOIA
I did the conversion for a customer of mine and I had to order the Toms crossmember to make it not interfere with the front driveshaft
