Transmission color
Rick Harrison
Shreveport
I have 2 things on my mind I have had my c4 rebuilt and need to paint it I have a 96 302 that I painted ford blue thanking about painting the trans. the same color what do you thank also I have a timing issue if I have it on top dead center the rotor is pointing to the right of the engine if iam standing in front of the bronco is this right thanks for your help
Ourobos
Big Island Hawaii
If you want the transmission blue, paint it blue, it's that simple. It's your ride.
Where the rotor button is pointing at TDC, is where the #1 plug wire needs to go, then wire in order from there. It technically doesn't matter where the button is at, as long as it's pointing at the proper plug wire at the proper time.
