Well after posting about 2 months ago and tearing the tranny/tcase out last minute for an event, my problem is not solved. 3Speed column shift/clutch replaced about 4 years ago.
Backgrond: When sitting in neutral the bronco begins to make a whining/spinning sound. It can get pretty loud. When you push the clutch in the sound goes away and no apparent sound when transmission is in gear (driving bronco).
Secondly, it has become very difficult to shift (3 spd column) into gear. it grinds alot and then as I slip it in you hear the gear final sleep as it sounds if everything is still spinning. I know this description is not great but I do not know what to think it is.
i was told throw out bearing so i pulled everything out and put a new one in. seemed better for about an hour and then back to have the noise. the clutch Petal does not feel right either when pushing it in and letting out. Other then the winning noise I do have trouble getting into 2nd or 3rd gear at all.
Please help me assess my problem. I have picked up a used c4 to have rebuild down the road. anyone in Md,PA,Va,WVa,DE or even Ny that can rebuild a C4 for a good price. I am willing to drive.
THANK You everyone for your help and suggestions.
Kyle V
Kyle V
