Transmission and vibration problems
joerazz68
Need advice. While driving my 72 bronco I noticed a bad vibration, then smoke everywhere. I was able to limp home and tranny fluid was spilling all over the place. I just had the c6 and the np205 rebuilt 3 weeks ago. I had installed 8 degree shims to try to get the pinion angle correct. The bronco has always had a vibration which is the reason the previous owner sold it. I'm not worried about the trans because it has a one year warranty. What would cause this repetitive vibration and why would it tear up the trans. Any help would b greatly appreciated. 3 1/2 inch duff lift. 302 c6 trans np 205
bknbronco
North Metro, MN
I wouldnt use the same tranie in the next rebuild. Get a different core and all different internals. Could be something inside that is out of wack causing it to go out. I had a blazer that kept exploding internal parts in its tranie and rebuilt it 3 times. The second time it went out was only 2 blocks from my garage on its test run. The third time it went out it had less than 100 miles on it. After the third rebuild i drove it slowly up to a used car lot and traded it in on a different truck! Good riddens to bad rubbage! Did the previous owner say he had that tranie rebuild recently? Maybe he was ditching that truck after rebuilding it 3 times! Why did you rebuild it the first time? Did they find broken parts ie broke input or output shafts, broke cages?
bknbronco
North Metro, MN
Oh and i forgot to mention that the second and third time it went out it took out my rearend! Way to much money spent on a blazer!
