rt22
I am having some problems with the transmission and starter after installing my new engine. Let me give you a little background on what I have: a new 351W from Ford. The C-4 transmission was rebuilt about 6 months ago but only has about 100 miles on it.
The new motor runs fine but the transmission will not shift into gear. I ran it through all the gears but it won't "kick" into gear. The fluid level seems to be okay and we hooked everything back up the way it was before. Does anybody have any idea as to what I may be doing wrong?
Also, after getting the transmission back (from the shop) I noticed that sometimes the starter was slow to repond when starting the engine. After we pulled the engine we noticed the starter had been chewed up near the tip of it (a groove was worn into the area). After installing the new engine we started the motor and it didn't take long before the new starter failed and the same groove was created. It looks like the starter dosen't line up. Do you think the people that rebuilt the transmission didn't shim something properly? I had a couple of issues with the shop that did the work so it wouldn't suprise me if something wasn't done right. They did tell me that they had to get another bellhousing because they dropped and cracked the original one. The transmission is under warranty but I want to make sure it is something they caused before I take it to them. Any advice would be appreciated.
