schneire
I had my c4 transmission rebuilt by a local reputable transmission shop about 3 months ago, but am just now getting around to road testing it. The problem is it won't shift out of first gear on its own and the transmission shop went out of business. So, I'm stuck trying to fix it myself.
I can manually shift it to 1st & 2nd and it feels good, but as soon as I shift to drive, it goes back to first.
I have verified the kick down is not bound and working correctly. I have tried 3 different modulators, verified the rod, and direction of the spool, and proper manifold vacuum at the modulator. Shouldn't it shift at high rpms/speed even if the modulator isn't working. It doesn't.
I have not dropped the pan yet, but if I do, what should I look for?
Could it be a governor problem? I think I have to pull the transfer case to verify that, but not sure how to check it either.
I also read that sometimes just driving it will loosen it stuff up and it will start shifting. I drove it around the block 4 times with no change, but had to stop to work on a brake issue.
