casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I'm attempting to tune my straight six with a vacuum gauge First concern I have is the vacuum at idle. According to the tech info I found over at classic inlines "normal" vacuum range should be 19-21 inches, or 15-18 inches on a low compression engine. My engine is freshly rebuilt and compression is about 9.3 to 1. I'm showing vacuum at only 17. Problem? Next, I set my idle air mixture and moved on to set the timing. I'm already advanced quite a bit with no pinging so I figured maybe I would try to go a little further. I tried to advance it further but the Dizzy hits the block so I won't be able to go any further without pulling the distributor and moving it over a cog or two. I'm not sure I should go to the trouble of moving it as I'm already sitt about 14-15 degrees. The guys over at FordSix.com say I should be able to go to AT LEAST 16 degrees with no problems at my elevation. Should my vacuum increase with more timing advance or decrease?
