DonH
This question is directed at Viperwolf1 but others can chime in.
When I got my 68 Project the wiring was a mess and I had to hotwire and jumpstart it to get it to run and I do not know if the turn and hazard switches worked. The EB came with a 12 circuit Kwikwire harness and I have to go with it. To complicate or simplify the project I am installing a new dash and AutoMeter gauges including a speedometer and tach. I have the wire harness installed and everything works except the turn signals. I wired the turn switch as the info sent to me from Viperwolf. I get 12v that is switched at the columm from left to right but there are no lights lit front or back. I sent Kwikwire an email and they said "That circuit requires a load for it to work". This harness leans heavely to the GM side for the install but show a few Ford drawings but nothing of Ford steering columm. Kwikwire support seems a little short.
How do I trouble shoot this thing to see even if the switch works? If I have to get a new turn switch can I adapt the newer type with the hazard built in?
How does the hazard switch work is it just a double pole double thro switch? Mine fell apart when I removed it from the dash. No luck at NAPA.
I am wondering if I should just get a aftermarket turn switch.
Thanks for any help.
Don
Don
