Recently turn signal fuse is blowing. Replaced a couple times and continues to happen. hazards are fine and lights work no problem.
Centech wiring harness and wh tilt column
Are the same bulbs and lights used for brake and hazards as turn signal? Could a bad flasher cause this? Am I likely looking at switch or wiring to fuse?
Thank you.
Thank you.
