Ok so normally my turn signal selector is great but I got out of the bronco went to the store and when I got back in the car it was completely loose and won't stay off or to the right. How do I fix this?
Sounds like the plastic cam under the steering wheel gave out and broke. That or the hold down screws came out. You'll have to pull the wheel and take a look under it.
If the plastic broke it will need replaced (more involved), the latter just tighten it down.
I replaced mine and got it from a Mustang vender as it was less expensive than the Bronco houses.
x3 on the steering wheel. My horn was not working so I pulled the steering wheel only to find out that I needed to replace the entire signal harness. Do it the right way. Takes just a couple minutes. Here is a wiring diagram just in case. It helped me a lot.
