twin stick dana 20 J shift install question?
rydog1130
Do i need to drop my T case to cut a notch in the shift rails? The hole I'm currently working with is pictured. If i have to make the hole bigger no worries as I was going to make an access panel to cover it back up
JB Fab
It's possible depending on the cutter you are using...
This is what I would use in your case
JB Fab
I know it's been done but I don't see how you would do it unless you drop the case a couple of inches.
rydog1130
rydog1130
I ordered your twin sticks from the graveyard. Will there be instructions? I don’t think I need any looks pretty simple I just need to make a cut straight down the middle correct?
JB Fab
Correct, And yes the shifters shipped from us with the instructions.
rydog1130
rydog1130
Cool! I’ll update this thread when I get to it! Probably when it hits 40-50 degrees here in Michigan! Currently it’s 10 degrees
