Twin Stick Tunnel Opening?
gnsteam
Lincoln NE
How much does the Twin Sticks/Transfer case, shift side to side while driving and off roading? Do I need to widen this opening? I currently have about an 1/8-1/4", on either side of the sticks.
.94 OR
Willamette Valley, OR
Seems a bit tight.
Since it would be hidden by the boot, can you relieve some material on the side of the shifter shaft, or bend the drivers side shaft at all?
EPB72
Pleasant Hill, CA
Seems a bit tight.
That’s what I Did a little bend in the arms away from me ,little heat and moves easily ,, I’d say u want more clearance
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I traced the inside of the metal twin stick boot plate and cut that out since thats pretty much the max size hole you can make.
904Bronco
San Martin, CA
What I did on Clifford... Shifters are in the Neutral position
