2badrotties
Just a Bronco guy !
Andy, No telling what you are dealing with. There must have been a reason for someone to park it all those years ago. It may have had a problem way back when. If you got it to run at all even for five seconds, I guess that is a good sign. Try turning the distributor a little each way and see if it spins easier. You just don't know what you may find.
The green 75 that I bought had rust on all of the valve stems even though it had a carb on it with air cleaner. One valve had stuck so bad that it broke a valve spring as I turned it over by hand. No telling what you may find as you go along. The exhaust may also be plugged solid ( mice nests ) after all this time. Just stay at it for a little while. Good luck
