thanks Jake. I haven't measured but I'm 100 or 101". I moved the front forward about 6" and the rear 5". These numbers are from the lifted lengths, which is why I'm only where I am.
I'm hoping Station's setup works as well as everybody says it will. I'm only running 3 degrees of castor, so I'm hoping that's enough for it to self-center.
The pinion angle is adjustable with the links, piece of cake. Loosen the jam nuts and adjust away. As far as the difficulty, the toughest thing is coming up with the lesser of 12 evils when it comes to compramises. Triangulation vs. ground clearance, vs. X vs Y. We'll see how it handles on the road. So far so good!!!!
