Upgraded Axles
Banjer Picker
Looking to upgrade soon. Would appreciate feedback from any of you guys that have upgraded to 31 spline axles. I have a small bearing ('73 bronco)housing, running 35s and will be installing a Detroit. Which vendor/manufacturer would you recommend?
Brandon
luderchris
SouthEast PA
Classic City Off Road. That is where I got everything when I rebuilt my 9" and they beat all other prices by a couple hundred bucks. Received all the correct parts within a week and they were easy to reach on the phone or by email.
Nightstick
Bronco guy
I like the WH extreme duty axles. They come with the bearings installed and use a tapered roller bearing which is better than the stock style bearing. All ya gotta do is take out the inner axle seal and throw em in, very simple. I'm sure others offer similar bearings and whatnot, but I try to support our vendors when possible. I got my seats from CCOR and like Luderchris said they have great customer service. They advertise in the vendor forum.
Banjer Picker
Banjer Picker
What are the advantages of the tapered bearings over traditional? Not sure that they are available dmfor the small bearing application. Regarding the seal removal...do you run it with no outer seal at all?
Thanks for the input guys
garberz
Bronco Influencer
Conejo Valley, Ca.
The tapered roller bearings only fit the big bearing housing. WH's has a 31 spline axle kit for the small bearing housing. It is a sealed ball bearing, like the stock one and you use the seal that's pressed into the housing. The tapered roller bearings for the big bearing housings use and outboard seal and the bearings are lubed buy the diff oil.
DirtyDave
I just installed a pair of the W/H 31 spline axles into my small bearing 9" yesterday and I can't say enough good things about them. I bought the Detroit and 4-11 gears from Complete Off-road.
Nightstick
Bronco guy
If I were you Brandon, I'd try to find a large bearing housing a drums. I bet that "ford heaven" guy on Craigslist has one and if you don't want the third member you could probably get it cheap. The large bearing style WH has makes life easy.
Kyle.malone
Norman, OK
I was in your same boat with the upgrade. I was stuck with a small bearing housing myself. You can either go with the 31 spline axles that WH has for the small bearing housing or locate a big bearing housing locally or go with the currie housing that WH sells like I did. I was really impressed when it arrived.
