Did you install resistors on the turn lamps, or change the flashers to LED compatible type?
LEDs don’t draw much current so the old mechanical flashers won’t work with them - unless you use the resistors.
Yes, I did install the equalizers that came with the kit. Based in the TBP video, it's one for each side of the bronco so odd that neither side is working.
LED bulbs, and flashers, are sensitive to polarity. If you have something reversed, like a bulb or a flasher, it may not work.
I really don’t know why these kits come with resistors except that it’s cheaper for the vendor. It requires hacking up your wiring and adds another point of failure..... it’s much easier to just replace the flashers with LED flashers.
I have to agree. I’d rather put a few extra bucks out and then start cutting in the wiring. Do any of the kids come with the new flashers? This is something I’ve been looking out for my bronco.
Sent from my iPhone using Tapatalk Pro
Agreed. Plus kind of defeats the advantage of less current draw.
open to all options. I'll report back. If I buy the LED Flasher, do I need to remove the equalizers that came with the kit?
Still struggling with this. I switched the wires that the equalizer was attached to on the drivers side of the truck.
I did have blinkers until I screwed in the taillight which either grounded / ungrounded it. No Blinkers.
I added an LED flasher. Removed the equalizer (drivers side). No blinkers.
What's next?
Do the lights come on but just not blink? The polarity may be wrong on your flasher. It’s easy to make a couple of wires to switch the connections. Some flashers come with them or an adapter.
https://upcarparts.com/led-flasher-w-reverse-polarity-base-extension-wires
