While I did see a vary of posts on this I guess it really depends what you have for a set up
Can someone save me some time on what upper & lowers hoses I would need
This is Toms radiator with a built in cooler
Thank you for the help
Those hoses linked above won't work with your setup. They'll work with a WH/Ron Davis 5.0 radiator with the switched inlets/outlets. For the top, the top hose that generally works best is the 68 Pontiac GTO hose (fits a bunch of other applications as well). For the bottom, some folks get the early '00s 7.3 Super Duty hose to work. Others use the crossover tubes that various vendors sell.
No , that is electric fan 2spd from a o4 jeep liberty, but it is on a stock original radiator with custom mounts and some trimming ,, three bolts across the top and one connector, could be removed sis minute or so..Oh o and to the OP my lower hose is the pipe WH sells and bronco lower hose cut to fit in place.
