Negative there ghost rider... That's how we know you! Start sneaking around as someone else and it'll make us all confuzzled like.
;D
In the meantime too, there are a couple of things you should be aware of. Hopefully you don't even need parts because those pesky '74 columns are a beast!!!!
Anyway, to that end maybe all you need is some tightening up of the lower retainer. Might as well check that first anyway. If it can save you some money and aggravation, then mission accomplished. If not, at least you tried.
Here is at least some of the many stock parts for a column like yours:
http://www.wildhorses4x4.com/category/Bronco_Stock_Column_Parts
What you should look for on yours, down in the open end where the shaft exits the column in the engine compartment, are a clamp (#2799) pushing against a sleeve (#2650) which is actually doing double duty as a preload adjuster and an inner bearing race. If that is loose from normal wear, you can simply loosen the clamp and push it a little farther up the shaft putting pressure on the collar/sleeve/thingy.
If the lower and upper bearings are just too worn out, then at least you'll know and can order up some parts.
Wherein lies the difficulty...
For some reason, '74 is the one we seem to get calls on most often for people rebuilding them and running into parts problems. Ford was making changes between '73, '74 and '75, and it seems your year got a mixed bag of parts sometimes.
My recommendation is to either take it apart first to verify what components you need (early vs late) or just buy bearings and such for early and late models so you have all the parts on hand you might need when taking the thing apart.
Then you can send anything unused back (at least if using WH that is) for credit or refund. I can't speak for the other vendors of course, so definitely ask to make sure that's part of their policy.
But try the adjustment first. Helps to have someone up by the wheel pushing lightly down while you loosen the retainer sleeve, as the upper spring behind the wheel will tend to push things upward and leave a larger gap between the wheel and column bell.
If the bearings are shot, you should know pretty quickly after tightening things down.
