[quote author=74bronc link=board=5;threadid=14649;start=0#110476 date=1046270805]
I am pretty sure the MSD's and Unilites have mechanical advance built into the distributor. You can adjust the advance curve using heavier or lighter springs. These distributors just don't have the advance controled by engine vacuum rather engine RPM. Get an adjustable timing light, check the timing at idle and then rev it up to over 3K and measure the amount of advance you have.
[/quote]
Just to clarify a thing about distributors.
All distributors that we are dealing with here (in broncos) have a mechanical advance. Unless you have some locked out race distributor. For the points and duraspark, it is mechanical. For fuel injection, it is often n the computer. anyway, as the engine spins faster, the spark must occur sooner so that the cylinder pressure is optimized. Gasoline is dumb. It doesn't know the engine is spinning faster, so we have to trick it by telling it to burn sooner (advance).
Vacuum advance is in addition to the mechanical advance. During high vacuum cruise, there isn't much cylinder pressure. That dumb gasoline is further apart (less pressure squeezing it together). So you trick it's stupidity a little more by telling it to light off sooner (vacuum advance)
If you are running a blower, there is the boost retard. That is because during boost moor of that dumb gasoline is packed together. you don't want to tell it to bur too soon or the packed croud will panic and spread the message too fast (detonate)
Confused?
More cylinder pressure, everything is packed and the word to burn spreads fast. So wait to tell it to burn.
Less cylinder pressure, tell it to burn sooner so it has a chance to get the word (flame front) to all the gas in the cylinder.
Communication occurs about the same speed, so the faster you spin an engine, the sooner you need to tell it to burn.
As for that last part, there are limitations Those F1 engines turning 18,000 RPM don't have 3 times the advance of my small block turning at 6,000.
Ok, to answer the original question. Run it. It should get you better mileage. If you don't, you may loose a little in the gas mileage department. That's about it.
