vacume fuel pump
NC-Fordguy
Bethel/Greenville NC
Searched the archives and found no answer....
I have a 66 Bronco with a 170 six cylinder.
Having issues with the load-o-matic system and have decided to upgrade to newer, less trouble prone components
Since I'd like to install electic wipers there will be no use for the vacume fuel pump.
Can I swap this over to a mechanical pump?? If so what do I ask for at the parts house??
NC-Fordguy
NC-Fordguy
Looked at NAPAs site and it's showing different pumps depending on model and year. For instance a 66 mustang with a 200 is showing a different pump than a 70 bronco with a 170
NC-Fordguy
NC-Fordguy
Well I've tried two different pumps this far
One for a 70 bronco 170 cid and another for a 66 mustang 200 cid and neither one have the same lever that contacts the cam.
I'm running out of ideas short of getting a block off plate for the port on the side of the engine and going with an electic fuel pump
I am surprised that it seems that no one on this board has ever tried this
widstje
Arlington
I'm going down the same path with my 67, inline 6, 170ci right now. The Autozone pump doesn't have the same angle on the lever. And I'd move to a electric but then I'd have to change my wipers.
Any ideas?
widstje
Arlington
I just picked up a fuel pump for a 67 Ford Econoline 2.8L 170cid motor at Autozone. Looks exactly like my old Carter. You'd of thought the part would show up for the Bronco when they search in the computer but it doesn't. Or maybe my engine isn't what I think it is?
Pa PITT
Stephenville TEXAS
Widstje what no. pump did you install..
.... I'm and old parts man from those days when the 67's were new .. as I recall when they stopped supplying the vacuum pumps. they give you the say 68 200 pump to use.. It wasn't exactly the same but it worked. But man It's been 20 years and I'd like to see that pump no widstje used ..
..........Some ford back in the day needed a spacer between the block and the pump or you'd mess up some real stuff .. But I think it was a V8 that used the 1/4 inch spacer and 2 gaskets .
73azbronco
Do what I'm doing, use the vacuum pump but run a short line from one side to the other on the vacuum ports.
