are you sure they arent the feed and return from the trans cooler? never heard of vac lines on a trans before?
I have one with a yellow stripe, what's the difference between the yellow and green?
There should be a lil bracket that bolts in to keep it from popping out
Yes that's what I'm missing! Thanks! Where's a good place to get one?
Could you not use a Y to connect the two hoses into one and run that to your single vacuum port?
Not really. The vacuum sources were not the same.
