Bronco Sully
Got a pesky oil leak that I think is coming from my passenger side valve cover so I am going to replace the gasket (for both sides). I tightened the covers down (not too hard, but the bolts all easily turned anywhere from a half turn to over a full turn) but that did not stop the leak. I ordered the gaskets from TBP along with some other fun stuff I plan to do over the holidays.
Couple questions:
1. Anything I should look for once the valve cover is pulled that may identify any lurking issues?
2. If the bolt holes are warped from over tighnening over the years, should I be able to just carfully tap those back flush with a hammer?
3. I plan on using RTV to help secure the gasket to the cover/head. I think that is pretty standard protocol. Any issues with using this?
4. What type of solvent/cleaner do you recomenend for cleaning up any leftover gasket, RTV, etc...?
Thanks in advance, first time valve cover gasket job for me.
Sully
Couple questions:
Sully
