Grapenuts
Does anybody know where I can get a new vented gas cap for my 74?
Thanks,
Grapenuts
Thanks,
Grapenuts
Sure, however I have found that most of them are actually not vented caps.mitzel said:pretty much every autoparts chain store should have replacement gas caps.
the most common ones I've seen are made by stant. go to the aisle with all the
stant thermostats and radiator caps, the gas caps should be right along side
those. there's normally an application guide hanging out there or check the
computer at the service counter for part# and you should be able to walk
away with a locking or non-locking cap for ~$10.
Grapenuts said:Thanks for the advice Edge, I installed new tanks and just plugged the vent lines. That is why I was looking for a vented cap, it looks like I will have to modify my filler neck or cap to let air back in the tank. It is creating a vacuum in the tank when it runs. I don't know if this will be a problem but I imagine it will get increasingly harder for my fuel pump to draw out fuel unless I can get some air back in the tank.
I have no trouble getting the vented here in "Coasty " area, at Napa. stock for my 68 yes they are crome , but the vent is on the inside to allow you to blow and hear a small whistle. I had your problem up on Blewet Pass a few years ago , and 2 new caps solve itGrapenuts said:Thanks for the advice Edge, I installed new tanks and just plugged the vent lines. That is why I was looking for a vented cap, it looks like I will have to modify my filler neck or cap to let air back in the tank. It is creating a vacuum in the tank when it runs. I don't know if this will be a problem but I imagine it will get increasingly harder for my fuel pump to draw out fuel unless I can get some air back in the tank.
