JakeAlex
Thanks for the instructions. Question… will the welds from the removed screws be sufficient to hold the pan in place or would you still have to go back and weld all the way around the seam? I would assume you would simply need to add seam sealer around the seam and be done with it. Correct?
Also, for those that have replaced their floors, did you replace the bolt that is located close to the front of the pan (just before the bend), or is there actually a need to?
