VIN build month discrepancy
Just picked up a project Bronco, sold as a 1968. The VIN on the frame and glovebox match and match the particulars of the vehicle. (289, no power brakes or steering etc) The only question is the build month code. D00301. The data bases say that is not a valid code for 1968 but matches one from 1976. Has anyone run into this?
Viperwolf1
electron whisperer
D00301 would indicate March 1968 or Jul/Aug 1976. The distinguishing thing is going to be the engine code. The 289 engine code in the 1968 VIN is N. In 1976-77 the only engine code possible was G.
P
U15NLD00301 BODY 9U98 TRANS C AXLE 18 The data base I found says 1968 March was
MarC98000 -C111999
I like your answer but what chart should I be using?
Viperwolf1
electron whisperer
MarC98000 -C111999
C111999 should really say D11999. This chart is more accurate than most.
1966​
1967​
1968​
1969​
1970​
1971​
1972​
1973​
1974​
1975​
1976​
1977​
aug732000-745999A00000-A13999C00000-C13999D82000-E01999G30000-G49999J70000-J79999M40000-M59999Q00000-Q19999S60000-S79999V20000 -V39999A00000-A24999O00000-O19999
sep746000-759999A14000-A27999C14000-C27999E02000-E21999G50000-G6999J80000-J99999M60000-M79999Q20000-Q39999S80000-S99999V40000-V59999A25000-A49999O20000-O39999
oct760000-773999A28000-A41999C28000-C41999E22000-E41999G70000-G89999K00000-K19999M80000-M99999Q40000-Q59999T00000-T19999V60000-V79999A50000-A74999O40000-O59999
nov774000-787999A42000-A55999C42000-C55999E42000-E61999G90000-H09999K20000-K39000N00000-N19000Q60000-Q79999T20000-T39999V80000-V99999A75000-A99999O60000-O79999
dec788000-801999A56000-A69999C56000-C69999E62000-E81999H10000-H29999K40000-K59000N20000-N39999Q80000-Q99999T40000-T59999W00000-W19999B00000-B24999O80000-O99999
jan802000-815999A70000-A83999C70000-C83999E82000-F01999H30000-H49999K60000-K79000N40000-N59999R00000-R19999T60000-T79999W20000-W39999B25000-B49999X80000-X99999
feb816000-829999A84000-A97999C84000-C97999F02000-F21999H50000-H69999K80000-K99999N60000-N79999R20000-R39999T80000-T99999W40000-W59999B50000-B74999Y00000-Y19999
mar830000-843999A98000-B11999C98000-D11999F22000-F41999H70000-H89999L00000-L19999N80000-N99999R40000-R59999U00000-U19999W60000-W79999B75000-B99999Y20000-Y39999
apr844000-857999B12000-B25999D12000-D25999F42000-F61999H90000-J09999L20000-L39999P00000-P19999R60000-R79999U20000-U39999W80000-W99999C00000-C24999Y40000-Y59999
may858000-871999B26000-B39999D26000-D39999F62000-F81999J10000-J29999L40000-L59999P20000-P39999R80000-R99999U40000-U59999X00000-X19999C25000-C49999Y60000-Y79999
jun872000-885999B40000-B53999D40000-D53999F82000-G01999J30000-J49999L60000-L79999P40000-P59999S00000-S19999U60000-U79999X20000-X39999C50000-C74999Y80000-Y99999
jul886000-899999B54000-B67999D54000-D67999G02000-G21999J50000-J69999L80000-L99999P60000-P69000S20000-S39999U80000-U99999X40000-X59999C75000-C99999Z00000-Z19999
aug900000-913999B68000-B81999D68000-D81999G22000-G29999M00000-M19999D00000-D24999Z20000-Z99999
